This document outlines the requirements, methods, and limitations for an IT administrator to remove pre-installed Microsoft Store apps (also known as inbox apps or bloatware) from Windows devices managed by Microsoft Intune.
1. Requirements
The requirements vary depending on the chosen method for removal. Microsoft now offers a native policy approach, but older methods (PowerShell or individual app assignments) are still available.
| Feature / Method | Windows OS Requirement | Intune/License Requirement | Deployment/Timing |
| New Native Policy Method (Recommended for supported OS) | Windows 11, version 25H2 (or later, specifically Enterprise or Education editions). | Microsoft Intune subscription with appropriate licensing. | Policy should be applied before the first user sign-in for full effect on new profiles. For existing users, they must sign out and sign back in. |
| PowerShell Script (Custom Method) | Windows 10/11 | Microsoft Intune subscription. | Deploy the script as a Win32 App or a PowerShell script policy. Should be configured to run in the System context and before the first user signs in for system-wide removal (Remove-AppxProvisionedPackage). |
2. Native Policy Method: Remove Default Microsoft Store Packages
This method uses a dedicated Windows policy (available via Settings Catalog or Custom OMA-URI) for a cleaner, supported removal of a curated list of inbox apps.
Configuration (Settings Catalog)
- Navigate to Devices > Windows > Configuration profiles.
- Click Create profile > Platform: Windows 10 and later, Profile type: Settings catalog.
- In Configuration settings, search for “Remove Default Microsoft Store packages from the system”.
- Enable the setting.
- Select True for each app in the list you wish to remove (e.g., Microsoft Solitaire Collection, Bing Weather).
- Assign the policy to your target device group.
Configuration (Custom OMA-URI – for environments without Settings Catalog support or before the setting is available)
- Click Create profile > Platform: Windows 10 and later, Profile type: Templates.
- Templates window: Click Custom and then select Create.
- Name and Discription“Remove Default Microsoft Store packages from the system”.
- Configuration settings >
| Setting | Value |
| Name | Remove Default Microsoft Store Packages |
| Description | Optional |
| OMA-URI | ./Device/Vendor/MSFT/Policy/Config/ApplicationManagement/RemoveDefaultMicrosoftStorePackages |
| Data Type | String |
| Value | <enabled/><data id="[PackageNameID]" value="true"/><data id="[AnotherPackageNameID]" value="true"/> Note: This XML value requires the specific id for each app you want to remove. Setting value="true" removes the app. |
Available values
<enabled/>
<data id="WindowsFeedbackHub" value="false"/>
<data id="MicrosoftOfficeHub" value="false"/>
<data id="Clipchamp" value="false"/>
<data id="Copilot" value="false"/>
<data id="BingNews" value="true"/>
<data id="Photos" value="false"/>
<data id="MicrosoftSolitaireCollection" value="true"/>
<data id="MicrosoftStickyNotes" value="true"/>
<data id="MSTeams" value="false"/>
<data id="Todo" value="false"/>
<data id="BingWeather" value="true"/>
<data id="OutlookForWindows" value="false"/>
<data id="Paint" value="false"/><data id="QuickAssist" value="false"/>
<data id="ScreenSketch" value="false"/>
<data id="WindowsCalculator" value="false"/>
<data id="WindowsCamera" value="false"/>
<data id="MediaPlayer" value="false"/>
<data id="WindowsNotepad" value="false"/>
<data id="WindowsSoundRecorder" value="false"/>
<data id="WindowsTerminal" value="false"/>
<data id="GamingApp" value="true"/>
<data id="XboxGamingOverlay" value="true"/>
<data id="XboxIdentityProvider" value="true"/>
<data id="XboxSpeechToTextOverlay" value="true"/>
<data id="XboxTCUI" value="true"/>
3. Custom PowerShell Script Method (Legacy/Fallback)
This is a common method for older Windows versions or apps not supported by the native policy, but it is not the officially supported method and can sometimes lead to issues.
- Identify the
PackageFamilyNameof the app(s) to remove (e.g.,Microsoft.BingWeather_8wekyb3d8bbwe). - Create a PowerShell script using commands like
Get-AppxProvisionedPackage -Online | Where-Object DisplayName -like "*Name*" | Remove-AppxProvisionedPackage -Online. - Deploy the script via Devices > Scripts or as a Win32 App with an uninstall command.
- Ensure the script is configured to run in the System context.
5. Limitations and Considerations
| Category | Limitation / Consideration | Details |
| Windows Version/Edition | Native Policy Restriction: The new native removal policy is officially supported only on Windows 11 Enterprise/Education, version 25H2 and later. | Using the native policy on Pro editions or older Windows versions may not work or is unsupported. |
| User Scope vs. Device Scope | Timing & Existing Users: The native policy primarily prevents provisioning for new user profiles and is a device-level setting. | For existing users, apps are typically removed only after they sign out and sign back in after the policy applies. |
| Apps Not Removable | Microsoft Edge: Microsoft Edge is often a notable exception and cannot be removed using these methods. | Other third-party OEM applications (bloatware) are also generally not covered by the native Microsoft policy and still require custom scripts or third-party tools. |
| App Reinstallation | Users can reinstall: End-users can often re-install removed apps from the Microsoft Store unless the Store itself is blocked or restricted via policy. | To completely prevent reinstallation, you must block the Microsoft Store, or use AppLocker/Windows Defender Application Control (WDAC). |
| PowerShell Script Risks | Unsupported Method Risk: Using custom PowerShell scripts (especially Remove-AppxProvisionedPackage) is generally unsupported by Microsoft and carries the risk of breaking Windows functionality or future updates. | Always test custom scripts thoroughly in a lab environment. |
| Conflict Management | Multiple Policies: Avoid applying both a Group Policy Object (GPO) and an Intune (MDM) policy for app removal to the same device, as this can lead to unpredictable conflicts. | Choose a single method of management for this setting. |
Reference: Policy-Based Removal of Pre-installed Microsoft Store Apps
