Managing Windows devices with Microsoft Intune often requires forcing a manual device sync—especially when policies are not applying as expected. While most admins use the Intune portal or Windows Settings, you can also initiate an Intune sync using Command Prompt (CMD).
This guide explains:
- How to force an Intune sync using CMD
- Why the sync command may fail
- How to fix missing Intune sync tasks
- How to confirm the device is correctly enrolled
What Is an Intune Device Sync?
An Intune sync forces a Windows device to immediately:
- Check in with Microsoft Intune
- Download new policies
- Apply configuration profiles
- Report compliance status
By default, devices sync every 8 hours, but manual sync is often required during troubleshooting or onboarding.
How to Force Intune Sync Using CMD
Intune uses a scheduled task created during MDM enrollment. Triggering this task forces a sync.
Step 1: Open CMD as Administrator
Right-click Command Prompt → Run as administrator
Step 2: Locate the Intune Enrollment GUID
Run:
You should see a path like:
\Microsoft\Windows\EnterpriseMgmt\6F3A8D3A-XXXX-XXXX-XXXX-XXXXXXXXXXXX\
This GUID represents the Intune enrollment ID.
Step 3: Trigger the Intune Sync
Replace <EnrollmentGUID> with the actual GUID:
This is the same action as clicking Sync in:
Settings → Accounts → Access work or school → Info
Common Error: EnterpriseMgmt Task Not Found
Error Example
Get-ScheduledTask : No MSFT_ScheduledTask objects found with property 'TaskPath'
What This Means
🚨 The device is not enrolled in Intune, or the enrollment is broken.
If the device were properly enrolled, the EnterpriseMgmt folder would exist.
How to Check If a Device Is Intune-Enrolled
Check Azure AD & MDM Status
Run:
dsregcmd /status
Look for:
AzureAdJoined : YES
MDMUrl : https://enrollment.manage.microsoft.com
❌ If MDMUrl is missing, Intune enrollment is not active.
Check Enrollment Registry Keys
reg query HKLM\SOFTWARE\Microsoft\Enrollments
- No keys → Device is not enrolled
- Keys exist but no tasks → Broken enrollment
How to Fix Missing Intune Sync Tasks
Option 1: Re-Enroll the Device (Recommended)
- Settings → Accounts → Access work or school
- Disconnect the work account
- Reboot
- Reconnect the work account
- Confirm Intune enrollment
Option 2: Force Auto-Enrollment via CMD
Run as administrator:
deviceenroller.exe /c /AutoEnrollMDM
Reboot the device and re-check the scheduled tasks.
How to Confirm Intune Sync Is Working
Event Viewer Logs
Navigate to:
Applications and Services Logs
→ Microsoft
→ Windows
→ DeviceManagement-Enterprise-Diagnostics-Provider
Look for:
- Event ID 208 – Sync started
- Event ID 209 – Sync completed
Key Takeaways
- Intune sync via CMD relies on EnterpriseMgmt scheduled tasks
- If the task doesn’t exist, the device is not enrolled
- Re-enrollment fixes most sync issues
- Always confirm Azure AD join and MDM URL
