How to Fix MICROCODE_REVISION_MISMATCH (0x17E) Blue Screen
Troubleshooting Guide: Resolving MICROCODE_REVISION_MISMATCH (0x17E)
Applies To
Modern Windows devices using Intel CPUs (especially Intel 11th Gen and newer, including hybrid architectures such as Alder Lake, Raptor Lake, and later). This guide is vendor-agnostic and applies to laptops and desktops from any manufacturer (HP, Dell, Lenovo, ASUS, custom builds, etc.).
Overview
The MICROCODE_REVISION_MISMATCH (0x17E) Blue Screen of Death (BSOD) typically occurs during sleep, hibernate, or wake-from-sleep transitions. The crash is triggered when Windows detects that different CPU cores are running different microcode revisions, which is considered a critical consistency failure.
To protect system integrity and prevent data corruption, Windows halts the system when this condition is detected.
1. Understanding the Error
What is CPU Microcode?
CPU microcode is low-level firmware that controls how the processor executes instructions. It can be:
  • Loaded by system firmware (BIOS/UEFI) at boot
  • Updated dynamically by Windows during runtime
Why the BSOD Happens
On modern multi-core and hybrid CPUs:
  • The BIOS loads a stable microcode version at system startup
  • Windows may attempt to hot-patch the CPU with a newer microcode revision
  • During rapid power-state transitions (sleep → wake), not all cores update at the same time
This temporary mismatch causes Windows to trigger:
Error Code
STOP CODE: MICROCODE_REVISION_MISMATCH (0x17E)
Common Triggers
  • Sleep / Hibernate resume
  • Fast Startup
  • Hybrid CPU architectures (Performance + Efficiency cores)
  • Firmware microcode older than Windows-delivered microcode
2. Recommended Solution: Disable Windows Microcode Override
The most reliable mitigation is to force Windows to rely solely on the BIOS-provided microcode, which is fully synchronized across all CPU cores at boot.
This is achieved by disabling Windows’ Intel microcode loader.
⚠️ This does not remove BIOS microcode updates and does not reduce system stability when firmware is kept up to date.
3. Automated Fix (PowerShell)
Step 1: Run as Administrator
  1. Right-click StartTerminal (Admin) or PowerShell (Admin)
  2. Copy and paste the script below
Powershell
# Define the target file and its new name
$targetFile = "C:\Windows\System32\mcupdate_GenuineIntel.dll"
$newName = "mcupdate_GenuineIntel.dll.old"
# Take ownership of the file
takeown /f $targetFile /a
# Grant full control to Administrators
icacls $targetFile /grant Administrators:F
# Rename the file to disable Windows microcode injection
Rename-Item -Path $targetFile -NewName $newName -Force -ErrorAction SilentlyContinue
Write-Host "Windows microcode override disabled. Please restart the system." -ForegroundColor Green
Step 2: Restart the System
A full reboot is required so the CPU initializes only using firmware-loaded microcode.
4. Verification: Check Active Microcode Version
After rebooting, you can confirm which microcode revision is currently active.
Microcode Status Report Script
Powershell
5. Maintenance & Best Practices
ActionPurpose
Keep BIOS/UEFI UpdatedEnsures latest stable microcode from the manufacturer
Disable Fast StartupReduces timing issues during resume
Monitor Feature UpdatesWindows feature upgrades may restore the DLL
Reapply Fix if NeededSimply rerun the script if the BSOD returns
6. Reverting the Change
To restore Windows microcode updates:
Powershell : Restore
Rename-Item "C:\Windows\System32\mcupdate_GenuineIntel.dll.old" "mcupdate_GenuineIntel.dll" -Force
Restart the system afterward.
Important Notes
  • Major Windows feature upgrades (e.g., 23H2 → 24H2) may recreate the DLL
  • This fix is widely used in enterprise environments for stability
  • Always prioritize firmware updates from your device or motherboard vendor
Summary
The MICROCODE_REVISION_MISMATCH (0x17E) BSOD is a timing and synchronization issue, not a failing CPU. By preventing Windows from injecting runtime microcode and relying on firmware-provided microcode instead, system stability during sleep and wake cycles can be fully restored.
This approach is safe, reversible, and effective across a wide range of modern Intel-based systems.
